Here's a quote from ** LiPo BATTERY CHARGER SAFETY WARNING ** that's on the bottom of a battery charger description page.
"Never overcharge or exceed a 1C charge current. A 1C charge current means the charge current equals the capacity of the battery. For example, a 2200mAh battery should never be charged using a current greater than 2.2 Amps (2200mAh)."
My questions is: If a battery specification says "Charge rate 3c" does that mean I can charge that "3c charge rate" 2200mAh at 6.6 Amps max?? Not 2.2 Amps as the warning says.
I'm thinking because of the Charge Rate of the battery specs being "3c", and not 1c. I can charge at that higher Amp rate.
Thanks,
Lon
Thanks,
Lon
