Battery size
  • revolver
    • 4
    • West Bend WI.
    Battery size
    I'm building a Trex 500X as a low head speed project , instead of using a 6s 3300mah I will be using the largest 4s battery that will fit. According to the weight and dimensions listed on MOTION RC, the Admiral 4S 5000's will fit. If somebody has these batteries could you verify the dimensions listed are accurate. Thank you.
    Weight 482g / 1lb, 3.80oz
    Length 155mm / 6.10in
    Width 46mm / 1.81in
    Height 30.25mm /1 .19in
