How about using and adapter on it? Will you still have the same performance as to using the correct end?
Admiral 3S LiPo - Lack of high mAh packs
The adapter will have a slight resistance. If well made it would be hard to measure the difference. However, it introduces several added potential failure points. Each connection, each solder joint is a potential failure point. Chances of failure with a well made adapter are low but they exist.
I use adapters on a regular basis, usually for charging other people's batteries with my field charging system. This is a lower load on the adapter and less likely to fail.
The adapter does not avoid the current limit of any type connector being used in the system. If the concern is the current limit of Deans, expect that concern to be the same with the adapter.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Hello Tom...............Any schedule update for this highly anticipated 3S 5000mAh 50C new product. :Drooling:Warbird Charlie
I just chatted with Wayne, here is what he told me.
"Dave Office Manager says Battery shipment due in the next 2 weeks so hopefully they sent them with it. They are supposed to be in there"Comment
Thanx DK............will be snaggin 12 of them buggars to get the fleet rebuild of support equip underway.;)Warbird Charlie
I like that pic Dan:Cool:...................saving it to the PC in jpg format for use on a banner inside the new garage where the fleet will hang;)Warbird Charlie
One picture says it all!
Great to hear the hangar is on track, how did you make out with the truck and trailer??
Grossman56Team Gross!Comment
Hangar has been getting delayed by better than a month due to winter.:P Vehicles..... See post #29 ;)Warbird Charlie
THANX Tom............Order #387468 placed for 6 of them which is half of what I need but it's a start on the support equip replacement program :)Warbird Charlie
So good to hear, great to see you're on the road to recovery on both fronts!
Bet you getting itchy to get building, this has sure put a delay on your schedule.
