Freewing Rebel V2 ESC Programing
  • fvignolo
    • Jun 2015
    • 3
    Hi Pilots,
    I purchased a Freewing Rebel V2 and I noticed the Throttle stick activate the electric fan not from the beginning of the throttle motion, meaning it will activate the electric fan probably after 6 clicks on the throttle or if we count the little lines on the throttle stick it will activate after 2 1/2 lines, is not like I can't fly the plane, is just that i'm not felling conformable having the discrepancy on the Throttle control.
    I already check my radio settings, (100%) weight and no mixing or offset settings.
    How can I correct this?
    Fernando
    [hr]
    Update ...
    Guys the only way that I'm able to correct this situation is adding 36% Offset
    But if anyone knows how to fix this on the ESC please let me know !!!
    Cheers
    Fernando
  • Pheonix
    • Aug 2013
    • 670
    RE: Freewing Rebel V2 ESC Programing
    What radio are you using? I will try my best to help.
    • fvignolo
      • Jun 2015
      • 3
      Hey Pheonix, thanks for your prompt reply.
      I have no issues with the rest of my fleet using the same setup.
      Setup:
      Freewing Rebel V2
      FrSky Taranis X9D (Firmware V2.0.17)
      FrSky Receiver X8R
      Fernando
      • Pheonix
        • Aug 2013
        • 670
        Setup:
        Freewing Rebel V2
        FrSky Receiver X8R
        Fernando
        I am not familiar with that radio.  Therefore, I have no idea where to start.  Try re-arming you ESC.  Perhaps something happened during the original arming.  Make sure the high and low rates (throttle) are set.  Wish I could help more.
        • fvignolo
          • Jun 2015
          • 3
          Setup:
          Freewing Rebel V2
          FrSky Receiver X8R
          Fernando
          Thanks !!!
          I already did the ESC configuration acording with MRC instructions, but same results, well I just modified the start up, I can try "Default Settings" and see the results ....
          UPDATE:
          After I reset ESC to default settings, still problem persist, I think I will keep my offset settings for now. I have some Freewing F-16 ESC's somewhere, probably I will try one of those..
          • Pheonix
            • Aug 2013
            • 670
            Setup:
            Freewing Rebel V2
            FrSky Receiver X8R
            Fernando
            Thanks !!!
            UPDATE:
            I would just give them a call if you have not done so.  They are very responsive to phone calls.  Wish I could help you more.
