1 x Freewing 70mm 12 blade 2100KV 2.6kg thrust 6S metal EDF positive propeller + 1 x Freewing
70mm 12 blade 2100KV 2.6kg thrust 6S metal EDF reverse propeller
Single set of parameters
70 metal ducted parameters: 1. Use of voltage: 6S = 22.2V
Use Motor 3065 2100kv inner rotor
Ducted thrust :2.5-2.6kg (blowing called test) 2.2-2.3kg (using the test fixture Test)
Current :65-75A
Weight: 300g
Leaves: 12 leaves
Duct diameter: 70.5mm Diameter: 73mm
Maximum speed: 46000 rpm
It's the same setup motion rc sells for upgrades on me262
so my ? Is can I use 2- 85 amp esc's on this setup???????
Current :65-75A
Weight: 300g
Leaves: 12 leaves
.png)
