If a video showing how to correctly install a separate BEC to both an opto ESC, (one that does not have an BEC built in), and a standard ESC, that would be very helpful to many of us. I have never used a separate BEC, but am wanting to build a larger Piper Cub ARF model with 4 standard size servos and not sure that the normal 5amp BEC included in the ESC would be sufficient. The Cub is a 71" wingspan, and will be running 4 standard metal geared digital servos. I want to make sure I won't have any issues once it is in the air. I will be using a full range 4 channel Spectrum receiver.
Thanks for the help!
