Hi all,
I was flying my FMS P-40 this afternoon, all was going well, when I noticed a loss of power. I was nowhere near my timer limit, but I started to circle to come back around and land. I had just dropped my gear when all power stopped. The prop quit moving, and I lost all control. Fortunately, I was over some fairly tall grass, and was in level flight. She just glided in with a slight nose down attitude. I kept trying to pull back on the elevator to level out, but I had no control. Luck was with me, it didn't hit hard, and only popped the landing gear loose on one side. Didn't even break a prop.
Once I got back to the bench, I checked the battery and had no reading at all on my battery analyzer. I could plug in a fresh battery, and everything came back to life. On further analysis once I got home, I could determine that one cell of the 4 went completely flat. The other three were at 3.91volts each.
So, I am pretty sure it was the battery that failed, and I see nothing from the plane that could have caused a drain on only one cell. If there was a problem, it should have drained the battery equally I would think.
Does anyone out there have any ideas what happened? I have several more of the same batteries and am wondering about them now. I always balance charge, and checked this one before flight and all cell voltages were close. Not exact, but close, and the battery was at 97% capacity.
Any thoughts or suggestions would be appreciated.
