ZTW Gecko 155A with JP EDF
  • Suhast
    • Nov 2019
    • 9
    Hello do you know if the ZTW Gecko 155A is good to run with the JP 8S 90mm EDF? I have red that these engines require 12 pole compatible esc, any firmware update for the gecko?
    also what is the difference between the 155A sbec version and the 150A HV opto? Ehat advantages has the HV over the SBEC version?
    regards.
    • 8814
    If you read the specs, it will tell you that the 155A with SBEC is only for up to 6s. It will not work for an 8s application. You need the “HV” one for that. “Opto” means there is no built in BEC. You need an external BEC.
