If anyone can give me some guidance it would be greatly appreciated. I have the Hobbywing Programming Card that I have used on my Freewing Jets, and it has worked perfectly. I just upgraded the EDF Motor on my 90mm T-45 to the 4068 In-Runner. When I hook up the card to the BEC, I get no LED lights to activate for the different functions of my ESC. No connection... When I replaced the EDF Motor, I left in the place the original 130 amp Hobbywing ESC. This Jet is about a year and a half old. Do I need to get a different Programming Card for this ESC?
Hobbywing ESC Program Card
Tags: None
Hi, if the esc is the same and it worked with the old motor, can't see you would need a different card. I have on occasions found that nothing lights up (Hobbywing card) when connected, whereas worked okay previously. After a few connects disconnects etc all came good. Perhaps connect old set up and check, see where you stand from there. This post is probably a bit late for you but thought I'd respond anyway. hope it helps.
cheers.
