Hey all, I am going to try out some other features built-in to the MCB-D that came with my Freewing F-18C. Specifically lighting and gear door sequencing. My question is without hooking up the unit to my radio and battery, 'cause I am just that lazy, does anyone know if the the output voltages are all the same for all 5 of the lighting slot options? Best, LB
MCB-D or Multi-Function Control Box (Blue Box)
Hey Elbee, I am 99.9% sure they are. It just wouldn't make any sense if they weren't.Originally posted by Elbee View PostHey all, I am going to try out some other features built-in to the MCB-D that came with my Freewing F-18C. Specifically lighting and gear door sequencing. My question is without hooking up the unit to my radio and battery, 'cause I am just that lazy, does anyone know if the the output voltages are all the same for all 5 of the lighting slot options? Best, LB
James, Thank you for the reply. I did go ahead and hook everything up on my Freewing F-18C and all outputs are the same. What I really like about this MCB is it eliminates all the other light sequencing and landing gear sequencing add-on hardware and puts control in one box. So, I am simply adding a resistor to drop voltage to 3 volt where needed for my Formation and NAV light modifications. Bravo Zulu to Motion RC again. Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
