Carbon vs Pro
  • msdt74
    Crash Test Dummy
    • Apr 2019
    • 15
    • Louisiana
    Carbon vs Pro
    I am flying an Admiral Pro 6s 6000mah 50C in my 1600mm Corsair. I am looking to buy 4 more batteries. I am not a full throttle guy(I will make 1 or 2 speed passes on each pack). Most of my flying is 60%-75%. The Carbon 5100mah 70C looks enticing and its cheaper(not by much). Is it worth swapping to the Carbon? I am not concerned because of the higher C rating, I am concerned with the difference of flight time. Thanks in advance.
  • Tipstalled10
    • Sep 2023
    • 21
    • U.S.A. Georgia
    I am having the same kind of questions. I have the Gripen with thrust vectoring. Only have 3 warmup flights on it and have not used the TV unit, yet. Using Admiral 4000 mah 6s Pro batteries and they do ok. Flight time is kinda short and I can only think it will get shorter once I get flippy with it ! I was seriously looking at the SMC Lihv cells or the Carbon 5100 70c. I like the promise of extra power with the LIHV although my present charger would need to be upgraded. The discharge curve on the Carbon 5100 looks enticing. I am leaning towards those since I have the charger for that. If you have used the Carbon 5100 in the past 3 years what was your experience ? I did see a video of a Freewing Twin 80mm edf using the Carbon 5100 and the giggles by the pilots seemed to indicated they were impressed! They got over 5 minutes of mixed flight.
    • MichelleNMayo
      • Apr 2025
      For optimal results, consider your flying style and the specific needs of your aircraft. If you want longer flight times without sacrificing performance, testing Carbon batteries may be worth a try as they are compatible with your charger.
      raft wars
      • helendam.lyly
        • May 2025
        • 3
        I am flying an Admiral Pro 6s 6000mah 50C in my 1600mm Corsair. I am looking to buy 4 more batteries. I am not a full throttle guy(I will make 1 or 2 speed passes on each pack). Most of my flying is 60%-75%. The Carbon 5100mah 70C looks enticing and its cheaper(not by much). Is it worth swapping to the Carbon? I am not concerned because of the higher C rating, I am concerned with the difference of flight time. Thanks in advance. Baseball Bros IO​
        How long do you typically fly on average with your current 6000mAh pack in your flying style? Because if the difference isn't too big, it's easier to decide between performance and price.
          • 8831
          Posts #3 and #4 above ................. recent joins, first, single replies to a very old thread. "Strange" user names. Composition of posts seems generic, almost non-sequitur. Keep an eye on these. Waiting for other shoe to drop.
