L_39 Landing gear Issue
  • ruthib4
    • Mar 2022
    • 3
    HI, I have a L-39 and it was very happy with it but suddenly the landing gear stated with issues. During a flight when trying to land, the gears didn't open and had to belly land, when i reviewed it and the gear open on the ground and after that it opens randomly.
    Any idea?
    • 5385
    Are the gear loose between the strut and retract unit? The set screws may be loose. Could the pin be bent, did you have a hard landing?
    • ruthib4
      • Mar 2022
      • 3
      Thanks Evan, nope, they all are tighten
      • ruthib4
        • Mar 2022
        • 3
        I did not had any hard landing, It just started like that during flight, before that flight.
          • 5385
          Look in the retract mechanics and there is a jack screw that move a slider along to extend or retract the strut. Take and apply a little grease on the jack shaft. Lithium is best but even vaseline will work.
          • Tigercat
            • Jun 2020
            • 9
            Are all three gear not going down if that is the case I would che k for a loose connection in the retrac wiring starting at the receiver. Check for loose or bent pins .
