phoenix 160 amp esc and 230kv motor
  • jhlagesse
    • Mar 2021
    • 5
    I have a plane where I was using a Phoenix 160 amp esc and an Avian 8075 230kv motor...the esc keeps shutting off and sometimes gives an overcurrent beep alarm. Using a 12s set up, is there anything I can do to prevent this from happening? I looked at the manual and found no help.
    • 8814
    Have you tried reducing your prop size and pitch?
    • margaretestrada
      • Aug 2023
      Originally posted by jhlagesse
      I have a plane where I was using a Phoenix 160 amp esc and an Avian 8075 230kv motor...the esc keeps shutting off and sometimes gives an overcurrent beep alarm. Using a 12s set up, is there anything I can do to prevent this from happening? I looked at the manual and found no help. angry gran​
      Or you also can try replacing your ESC. The Phoenix 160 amp ESC is a high-quality product, but it’s possible that you received a faulty unit.
