afterburner
  • afterburner
    hi,all i've just installed Freewing Tail Flame Afterburner LED Lights for Select 80/90mm Freewing,just connect cable all led on but start to beep beep ,,,can someone help...
    tks
    What is going beep beep? The controller, the ESC or the EDF unit. What ESC and receiver are you using? ARe the LEDs on all the time or just when you open the throttle?
    It's very hard to help when you give incomplete information.
      I suggest revisiting the connections and ensuring the cables are seated correctly in their respective ports. wordle unlimited
