Scorpion A 6528-160
  • Clugh
    • Sep 2023
    • 5217
    Scorpion A 6528-160
    Louis Fourdan is Recording real scorpion data in an acceptable way serious modelers can compare to.
    Scorpion motors and kits - RC Groups​
    Hi
    I have received from Scorpion one motor A 6528-160 (s/n XF 0004). Thanks Kyle.
    Including 3 gold 6 mm F connectors + 3 black thermo-tubes.
    Configuration is 12N14P dLRK
    Stator size 65x28 mm
    Windings: 8 turns per tooth (16 conductors per slot), 2 strands of 1.12 mm wire, terminating delta
    Presently, I have not opened the motor yet.
    Weight is measured 1100g (with only the black drum rotor side solidly bolted on the rotor and 4 stator M4 screws)
    Accessories weights:
    * Cross 46.5g
    * 4 screws to fix the prop 27.5g
    * Wafer for the prop 11.75g
    * 2 nuts M10 for the prop 11g
    Total is around 1198g without stand-offs
    Stator mounting: 4 holes for M4 screws on circle 32 mm.
    Bell outer diameter = 78.5 mm
    External shaft diameter = 10 mm 1.25mm pitch, 44 mm free
    Internal shaft is 12mm. BBs are two 12x24x6 ZZ (6901)
    Overall shaft length = 137 mm (internal diameter 12mm)
    End bell with a black drum Ø40mm, 20mm high, 4 screws M5
    Bell flange is managed with 8 spokes (Y shaped)
    The end of the shaft (prop side) is drilled & screwed M5 on a depth 25mm
    As usual for my tests, I first make only no-load tests.
    I have used my favorite (for my bench) Scorpion Commander ESC 130A 50V opto ESC equipped with
    * 6mm gold F connectors.
    * My own rpm phase sensor providing Hz on a DMM (here under my Mustool MT108T)
    First rapid checking, running under 12V, on my new bench (profile T-Slot 20x80mm).
    All is OK, very smooth rotation, low noise.
    I have made a special mounting corner in light alloy to the fixing on my profile. (cross not used)
    First testing is phase-phase resistance (3 DMM measurements under 5A CC: 90, 88, 92 mV dc)
    Average Rm = 0.0180 ohm @ 35°C (this summer!), that is around 0.0169 ohm @ 20°C
    Secondary testing is no load, WOT, under my new PSU: Riden RD 6024 60V 24A (with a pretty color display)
    + ESC + servo tester LETON (powered by external 5V Scorpion guard).
    My PSU RD6024 is source-powered by two battery packs LiFePO4 providing 56 V DC
    The advantage of a regulated DC/DC converter is that the voltage is very stable, adjustable by one knob and very accurate (calibrated by Riden).
    On the picture the A 6528-160 is numbered "8"
    The ESC Commander is numbered "5"
    I fill a table (manually on a paper sheet) voltage, no-load current and rpm (via Hz), from 12V up to 46V steps 2V. Note than my ESC Commander is not working under 12V.
    Then my usual EXCEL template to finish the no load analysis, and transforming Hz into rpm:
    Zero current Kv is rounded at 161 rpm/V.
    Io no load at 44V is measured 3.07 A
    To complete the analysis, I have, in the future, to embed the data in Scorpion Calc (soon) v 3.98
    Temporarily I have edited a new motor A 6528-160 on SC v3.97 with the measured parameters
    General personal comment:
    The A 6528-160 is a very good beast, with a wonderful and modern design.
    Kv around 161 rpm/V is interesting under 12S.
    The robust windings (2 strands 1.12mm) is providing an excellent low internal resistance 17 milliohm compared to close competitors).
    Also, I prefer a configuration 12N14P versus 24N28P used for some motors in the same class (160 Kv range 1000g weight).
    In the future I hope to also test the brothers A 6528 -180 and -200 rpm/V
    I recommend a voltage range 40V ... 50V (10S ... 12S LiPo)
    Examples (suggested by Scorpion) on 3 typical propellers
    12S; Falcon 20x10E; 45.6V; 44.7A; 2038W; 6397 rpm
    12S; Xoar 24x12E; 44.6V; 80.3A; 3581W; 6085 rpm
    12S; Xoar 26x12E; 44.2V; 103.9A; 4592W; 5808 rpm
    In the future, I must see what props I could test with my friend Olivier (in flight).
    I plan to test with him on a Tucano, span 2.8 meter, weight around 16-17 kg
    Prop to test is a 3 blade 25x12 PT model carbon (possibly cut down 24 inches) on 12S
    This post will be followed by other reports
    a) Back to back testing with a Flipsky 6354 BLDC motor (driver-driven exchange), close Kv 156 rpm/V
    b) Loading by electronic 3 phases load (no prop) on the driven 6354
    c) Examination of the BEMF signal on an oscilloscope (6354 as the driver)
    Louis​
    Click image for larger version  Name:	EXCEL screen shot A 6528-160.webp Views:	6 Size:	112.9 KB ID:	389803
    State-of-the-art PMSM/BLDC motor control solution for aerospace applications and robotics - Télega - Zubax Robotics​
  • Clugh
    • Sep 2023
    • 5217
    ​ Scorpion A 4225-500
    Hi
    I have received from Scorpion one motor A 4225-500 (s/n XE 0039). Thanks Kyle.
    Including 3 gold 4 mm F connectors + 3 black thermo-tubes.
    Stator size 42x25 mm
    Windings: 5 turns per tooth (10 conductors per slot), 23 strands of 0.29 mm wire, terminating delta
    Weight is measured 414g (including cross 17g, screws, bullets connectors and prop hub) but without stand-offs
    Stator mounting 4 holes for M4 screws on circle 25 mm.
    Bell outer diameter = 50.7 mm
    Prop shaft diameter = 8 mm M8 1.0mm pitch, 35 mm free
    Internal shaft is 6mm. BBs are 6x15x5 (NMB 1560 KK)
    Overall shaft length = 137 mm (internal diameter 10mm)
    End bell with a black drum Ø40mm, 12mm high, 4 screws M4
    Bell flange is managed with 6 spokes (Y shaped)
    I have made a special mounting corner in light alloy to the fixing on my profile. (without the cross)
    First testing is phase-phase resistance (3 DMM measurements under 4A CC: 51, 51, 51 mV DC)
    Average Rm = 0.0128 ohm @ 20°C
    I fill a table (manually on a paper sheet) voltage, no-load current and rpm (via Hz), from 12V up to 32V steps 2V. Note than my ESC Commander is not working under 12V.
    Zero current Kv is rounded at 492 rpm/V.
    Io no load at 24V is measured 2.53 A (see picture of the table no load)
    Temporarily I have edited a new motor A 4225-500 on SC v3.97 with the measured parameters
    The A 4225-500 is a very good motor, with a modern design.
    Kv around 492 rpm/V is interesting under 6S.
    In the future I hope to also test the brother A 4220-540 rpm/V
    I recommend a voltage range 20V ... 30V (5S, 6S, 8S LiPo)
    Examples on 6S (suggested by Scorpion) on several typical propellers
    6S; Xoar wood 16x8E; 21.4V; 86.2A; 1845W; 9091 rpm; static thrust 5.56 kgf
    6S; Xoar wood 17x8E; 21.2V; 103.7A; 2198W; 9091 rpm
    6S; Xoar wood 17x10E; 21.8V; 127.2A; 2773W; 8611 rpm
    6S; Xoar wood 18x8E; 21.8V; 126A; 2747W; 8600 rpm; static thrust 8.08 kgf
    6S; Falcon CF 18x10E; 21.2V; 126.7A; 2686W; 8368 rpm; static thrust 8.6 kgf
    3D Airplanes 67”-70”; warbirds 67”-74” up to 8kg
    a) Back to back testing with a HK 5535-450 PAW (driver-driven exchange), Kv 462 rpm/V
    b) Loading by electronic 3 phases load (no prop) on the 5535 driven motor
    Louis
    ​ Click image for larger version  Name:	A-4225-500kv-tests no load_01.webp Views:	0 Size:	88.0 KB ID:	389805
    • Clugh
      • Sep 2023
      • 5217
      Hi Borat
      I also have some comparative 42 series data here In this thread from 2009 🙈🙉🙊
      powerscorpion 42XX | RC-Network.de​
      • Clugh
        • Sep 2023
        • 5217
        • Clugh
          • Sep 2023
          • 5217
          • Clugh
            • Sep 2023
            • 5217
            Click image for larger version  Name:	A 6528-160_01.jpg Views:	0 Size:	20.7 KB ID:	406460
            Configuration is 12N14P dLRK​
            Knock Knock
            :no_mouth:
