Battery Voltage
  • Espinca
    • Dec 2013
    • 4
    Battery Voltage
    What is the lowest battery voltage I can flight without damaging the batteries or having problems with the plane?
  • Tom
    Super Moderator
    • Sep 2013
    • 905
    Re: Battery Voltage
    I shoot for 3.75V per cell. Ideally you want 3.8V per cell but I usually end up at 3.75. This is resting voltage after the plane has landed. Your LiPo will see far lower per cell voltages under load.
    • Espinca
      • Dec 2013
      • 4
      Re: Battery Voltage
      Thank you, big help.
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        Re: Battery Voltage
        Let me know if I'm mistaken, but my understanding is that 3.8v-4v is a fully charged lipo cell and 3v is the minimum safe voltage. Thanks The Doctor
        • WintrSol
          • Nov 2013
          • 499
          • Florissant, MO
          Re: Battery Voltage
          Unloaded and rested, 3.7V is about 20% charge, 3.8V is about 40%, and 4.2V is full charge (actually ~4.23V-4.25V, but you risk damage there). Storage charge is suggested to be 3.8V-3.9V, to maximize battery life. Minimum voltage under load, of course, depends on how many amps are drawn, but shouldn't go below about 3.0V at high currents, 3.3V at moderate currents, relative to the C rating. For longest battery life, you shouldn't discharge below 20%, and never, ever, overcharge.
          • doctormike
            • Oct 2013
            • 1260
            • Santa Fe NM
            Re: Battery Voltage
            Thanks! I think this will clear this for a lot of RC pilots. The Doctor
            • WintrSol
              • Nov 2013
              • 499
              • Florissant, MO
              Re: Battery Voltage
              A web search will reveal much of this info, but much of what you find is rather stale, due to improvements in the chemistry. There are folks over at rcgroups who have studied batteries much more thoroughly than I, and keep their data fresh, which is mostly where I get my current data. Unfortunately, many ESCs are still programmed with a cutoff voltage for older batteries, and is too low for the current batteries, so a flight timer, and a charger that shows charge put back in, are your best bet for battery life and safety.
              • Tom
                Super Moderator
                • Sep 2013
                • 905
                Re: Battery Voltage
                This is very important and worth mentioning. Do not hit the LVC cutoff on your ESC. This will severely shorten the life of a LiPo.
                • StarHopper
                  • Aug 2013
                  • 230
                  Re: Battery Voltage
                  Tom, By "do not hit" are you talking about not running your LiPo down to the LVC? I presume so (no counter-logic available), and must say I find your supposition .... surprising?
                  First, the LVC is, on most 'better' ESC's anyway, a setting. Pick one higher than lowest LiPo per-cell Voltage recommendation. Available choices are usually purpose-driven. Choose wisely, if that needs saying.
                  And secondly, remember what an LVC does .. what it's <i>for!</i> It's a protective device.
                  eg, when it comes down to bringing down a $350 plane safely vs punishing & possibly toasting a $40 LiPo, guess who gets to play the Sacrificial Lamb?
                  • WintrSol
                    • Nov 2013
                    • 499
                    • Florissant, MO
                    Re: Battery Voltage
                    Bringing down that $350 plane, dead-stick, can be a real problem, too, especially if it is a warbird. Use a timer, or remote sensing, and avoid a difficult landing, IMO.
                    • Tom
                      Super Moderator
                      • Sep 2013
                      • 905
                      Re: Battery Voltage
                      The LVC is a great device to save a plane but it should never be relied on. When the LVC is set to the highest setting available for a LiPo, it is still too low and will raise internal resistance in the LiPo cells. Running a LiPo pack to LVC one can permanently damage a pack and doing this on a regular basis will severely shorten the life of a LiPo pack. I've tested this with many different brands of packs using packs of the same age with the same number of cycles as control (the control group does not hit LVC). The packs which hit LVC die an early death and IR increases.
