I have an asp 61 glow engine I bought 15 percent nitro fuel the instructions recommends 10 percent can I mix 1 gal of 5 % and 1 gal of 15 % and get 10 % it works mathematically
nitro glow fuel
Tags: None
It should, but make sure the lubricants are also compatible. It shouldn't be necessary, though; most glow engines will run fine up to 20% nitro, and many run best at 15%. If you are concerned, don't fly it really hard, until you use up the fuel.
What is RC glow fuel? Learn everything you need to know about nitro fuel ingredients, castor vs synthetic oil, blends, and how to choose the right fuel.
I have 2 asp engines. 1 asp46 and 1 asp91. The instructor and president has nothing but asp motors in most of his planes. Seems he flies a different one every week and all he will fly in them is 15% where as most of the others fly 10%. I fly 10% in both of mine because its only 18.95 a gallon as opposed to 26.00 a gallon.;):)Dewey lComment
thats what I use on my rc buggies, .21 engines...
runs better than any over priced car fuel, traxxas, o'donnell, etc.Comment
Not sure on airplane engines, but thats a monster of an engine.
Shim it right, check temps and you should be fine w 15%. Many manufacturers try to be safe. And more than the nitro content, look for amount of oil in the fuel as well.Comment
