Using a voltage tester while in flight..
  • Howtech
    • 4
    I've seen/read that it's ok to have one of those compact voltage testers on board while flying. Last wknd a friend and myself had an unexplainable crash with our birds and the only thing that I can narrow it down to is this tester. Anyone else run with one of these with any problems? Thanks in advance.
  • fredmdbud
    • 450
    I've done that, and no, I've never had that problem.
    • Howtech
      • 4
      Thanks Fred! From now on I'm just going to rely on my timer and forget about the voltage checker.
      • rustygunns
        • 10
        • Boston Ma.
        Just back from the field, ran 3 packs thru my FT22 with volt checker on it and no issue's. Think I'd dig a little deeper before I put that bird in the air again
        • crankestein
          • 316
          The volt checker is not heavy?
          • PappaBear
            • May 2015
            • 377
            • California
            The problem with using an onboard battery checker in the model is you can't actually see while the model is in flight. Unless you use a timer and time each flight the only other way would be to use an onboard telemetry system and have a read out on the TX screen.
            Martin.
            • Howtech
              • 4
              Martin, the voltage checker that I'm using has an extremely loud beeper when the preset setting is reached. I intended to use it as an audio alarm.
              Crankestein......the unit is very small and light. 1"x1.250"x.375" at most.
              • bigron3@gmail.com
                • Sep 2016
                • 5
                I use 1 all the time. They have nill draw and are pretty easy to hear. That way I don't have to rely on the timer.
                • Tony617
                  Tony
                  • 54
                  • Washington State
                  I use a low voltage monitor in most my RC airplanes that have propellers. The ones that use them on is my EDF planes since they are so loud there is no point. I use the timer on my transmitter and I have never had my RC crash due to the LVM. The LVM weighs very little.
