Keeps Going Into Program Mode?
  • Pauly
    Just Fly It
    • Apr 2015
    • 469
    • Warsaw, NC
    I've recently purchased the Dynam P47 and I have like usual had some issues with the retracts when trying to test them with a servo tester. One however works flawless and the other doesn't seem to work at all.. I have tried two different retracts and the same issue with those as well. So I was told then to go ahead and hook up everything and run it all through a receiver. So I put in a new receiver and did the bind and when triying to set it all up my receiver keeps going into program mode every time I plug in a battery. I have done a defalt mode with the Dynam program card. I don't know what else to do. Even since I did the program card every time I plug in the battery I still keeps entering program mode on the ESC.
    Still Learning:D
    • 8814
    Your throttle is backwards. With your stick down, it's seeing full throttle. Go into your servo menu and reverse the throttle. Also make sure the throttle trim tab is as low as it will go.
    • Pauly
      Just Fly It
      • Apr 2015
      • 469
      • Warsaw, NC
      Thank You Viper. I talked to Hippie last night on the phone and he suggested the same thing. I'll have to try that today. Thank You so much for the reply back.
      Still Learning:D
        • 8814
        Hope that's all it is. :Goodbye:
        • Pauly
          Just Fly It
          • Apr 2015
          • 469
          • Warsaw, NC
          I to was hoping that was all it was, but I think there is more to it or I'm doing something wrong. Now, since I reversed the position when I plug the battery in now it just keeps beeping really fast. Not the program beep music tones just beep,beep,beep never ending or stopping.
          Still Learning:D
            • 2137
            • On planet earth....right
            Just a couple things in hopes of getting to a solution through process of elimination.
            1. Is your throttle wires plugged in properly to the receiver with the correct polarity, i.e. black, red, and white wires are appropriate for the receiver?
            2. Does the ESC have a built in BEC, or a separate BEC? If it has a separate (external) BEC, make sure that servo lead is also plugged into the receiver on either a free slot or the bind port slot.
            3. I'm not sure how the Dynam ESC's operate with programming and calibration. However, if it's the same as some other ESC's, it can be calibrated by:
            - (important****please take off the prop and anything else that could potentially cause harm before doing the calibration****) turning on your Transmitter (the plane is not plugged in though),
            - put the throttle stick itself to maximum (al the way up)
            -provide power to the airplane by plugging in the battery, make sure you hear a beep (or beeps) and immediately put the throttle stick to the lowest position and you'll hear a few more beeps, which signifies the throttle has been calibrated and ready for use. Please be careful doing this and once again, take off the propeller and anything else before doing the ESC calibration, if this method even works with the Dynam ESC's.
            • Pauly
              Just Fly It
              • Apr 2015
              • 469
              • Warsaw, NC
              Thanks guys! I feel like idiot now that I got it fixed. I did reverse the throttle position, but I didn't zero the trim. I was told to make sure I did that when reversing the position and failed to do that at that time. I went back this afternoon and scratched my head and said a few uder words and went in the menu on my radio and then noticed it. As soon as I started to trim it out BINGO fixed. Thanks again heroes. The Squawk here is a awesome tool to have.
              Still Learning:D
                • 8814
                Great! Simple fixes are always the best.
                  • 2137
                  Woohoo! Enjoy the plane. :)
                  • farmflyer
                    • Mar 2015
                    • 1164
                    • Quitaque Texas
                    Just for clarification do you mean to set the trim to 0 or centered like on spectrum or tactic transmitters or all the way down on the negative side of trim.
                      • 8814
                      I'm sure Pauly will clarify, but with electrics, I believe it's best to go to the bottom on the throttle trim tab (or negative as you call it). Some ESCs won't arm if the trim is at the neutral (or 0) position. Neutral position is for liquid fueled engines where they have to idle.
                      • farmflyer
                        • Mar 2015
                        • 1164
                        • Quitaque Texas
                        Thanks I have asked this before but never got a clear answer. I fly all electrics and have always set from the (0) or neutral position they have always armed but some seem like they are not quite going to full throttle. I will try this and see what happens.
                          • 8814
                          Re-do the throttle calibration afterwards, just in case.
                          • farmflyer
                            • Mar 2015
                            • 1164
                            • Quitaque Texas
                            I will it will be interesting to compare the two to see if there is a noticeable difference in the overall throttle.
                            • Pauly
                              Just Fly It
                              • Apr 2015
                              • 469
                              • Warsaw, NC
                              I did go all the way back to 0 (-) position. There is rome that I can go up toward the center and may just end up doing that. I have to replace my retracts first. Thanks guys.
                              Still Learning:D
