Will the motor from a e flite yack 25 size 1.000k 60 amp swich mode bec work on a SBACH ESC ??? they are both 60 amp
ESC
AMP is one of Key parameters of Choosing best ESC for quadcopter. For BEC or UBEC, you really need to make sure which one you have or are buying if your goal is to have the better switching mode instead of the more problematic linear mode type BEC. (From below article) The maximum amperage an ESC can handle needs to be greater than the motor/prop combination will draw. If the amperage rating is not high enough, it could overheat and die.In terms of ESC, suggesting 20%-50% extra Amps is good rule to ensure your ESC do not burn out.
