Eagle A3 Pro no output to controlles
  • hanseriksson
    • Sep 2020
    I'm new to all this RC stuff so i need some help with this.
    I did buy a eagle A3 pro Gyro and installed it with a AR7000 Receiver + JR X9303 transmitter
    when i first installed it i was able to move the controls on the plane but the rudder did the ailerons and ailerons the rudder.
    allso the aux switch on the controller was able to change the function of the gyro (mode input)
    so i change the output wires to get the controller to work right , but now i have no control output
    if i turn the batt power on, the gyro powers on and works, if i move the plane the controls move opposite movement.
    it has a steady blue light after it goes through the start up. if i connect the mode input the gyro starts blinking blue.
    then when i power up the controller i have no control of anything,the receiver is connecting but no movements whatsoever
    im not sure if its the gyro setup or the transmitter that is acting up, any help is appreciated
    have gone through the setup menus on the gyro and can not see anything that would make a difference
    Hans
