I bought this new antennaless receiver last week at our local hobby shop here in Chilliwack B.C. It has no channel labels on it. I tried. to do some research on it . There's not much out there. I wanted this new Rx on my new plane.. The plane required a throttle calibration. The Rx has a push bind button built-in. No more bind plugs. Tried the 2nd and 3rd port for throttle, thinking this is the ports they use. Anyway I got fed up and used one of my old Spektrum Rx. Why wouldn't they label where the plugs go? I feel like taking it back and getting a normal one with a satellite.
New Spektrum AR620 sport receiver problem.
I can understand your conundrum..........rather peculiar that Spektrum omitted identifying each port in the manual as they have in the past on all other Rx.
The standard port ID for Spektrum 6 channel Rx's has never changed and is as follows.
1 Throttle
2 Aileron
3 Elevator
4 Rudder
5 Gear
6 Aux 1
As you look at the ports, to the very left you can barely see the - + S connector orientation for the servo
The ground (black/brown) is to the base/bottom of the Rx case and signal (white/yellow) is at top.
By using a Bind button they did away with the bind plug on port one and just re-labeled it as BATT which is what it normally served as on other Rx's such as the AR610Warbird Charlie
Sometimes, we just have to take matters into our own hands and use a little common sense to determine what's going on. Generally, RX's channel 1 is throttle. As for the rest, whether it be a Spektrum or any other brand, we can test for this. You can bind a RX WITHOUT it being in the plane. Just hook up a power source like an external BEC that's been wired to connect up at least a 2 cell LiPo and plug it into any port on the RX to power it. Once bound, use an old servo to test each port using the TX to see which stick activates that port. Or follow OV10's guide. On Spektrum, that is what they usually are unless you've programmed the ports to do different things. I've seen on non-Spektrum RXs, port assignments have been all over the place.
Ok thanks for replies. I have some servos to bench test the Rx with.Not ruling out the common sense but they could put the channel assignments in the manual for new guys.Sometimes I'm under a time limit to do things.Don't want to cut into sleep time crunching what's wrong. Thanks again I'll test it when I get home.
I thought I'd post this picture up to show what I've done to make up a very inexpensive set-up for binding and testing receivers and servos outside of a plane. It can also be used to do the testing when the RX is inside the plane. It involves the use of an external BEC, in this case, a Turnigy BEC and an old 3s LiPo that I kept for this purpose. The RX in the picture is even one of the 636A's out of my Opterra. Any old, spare servo will do and a bind plug. Power it up and bind it, take out the bind plug and you have a powered up RX that you can use with your TX to check out what each port does. I even use this BEC and battery to power my servo tester.
Can't see the bottom of the picture. It's cut off. "Battery" is only if you are using an external BEC but can't say for sure since the picture is cut off. D looks like it can be used for telemetry if you choose to have such a device or it can be used as "Port 1". Unless the ports (C) are labelled you still have to test them to know what each one is for.
If you use a typical ESC with a built-in BEC, the battery port (B) can be left empty. D is the throttle port, which will also double as providing power to the Rx from the built-in BEC in the ESC. Your TX can also show certain telemetry values automatically if it has that capability. You just have to scroll to find it (eg. Rx voltage). Ports 2 to 6 will likely be the typical arrangement for your servos. Do a test to confirm what each one does.
Originally posted by OV10 View PostI can understand your conundrum..........rather peculiar that Spektrum omitted identifying each port in the manual as they have in the past on all other Rx.
1 Throttle
2 Aileron
3 Elevator
4 Rudder
5 Gear
6 Aux 1
Originally posted by ajmitch51 View Post"Y" them together ? that's what I originally thought, but shop set up my Trex 470 with Spektrum AR610 Rx with "ail" for one side and "aux1" for the other.
Originally posted by Question65 View PostSo I got this ar620 spectrum reciver and I hooked it up to my 20 amp hitec esc and my motor powered it all on no trottle my servos work but no throttle
It's the lack of proper punctuation XV Put a coma after motor. Most likely the case of improper throttle stick calibration.Warbird Charlie
