What direction do you install a admiral Rx600sp. 6 channel dsmx receiver in the fusalodg
Receiver question
Originally posted by steveh80128@aol.com View PostWhat direction do you install a admiral Rx600sp. 6 channel dsmx receiver in the fusalodg
Quick Thought with regard to your user-name, you might want to choose something that is not your email, although that is not a requirement, just an encouragement.
I would be concerned about spammers and the like finding your email so easily.
Contact Aros here at the Squawk and he can assist in changing that for you if you choose.
Respectfully, LBI solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
INSTALATION – The Admiral RX600SP must be installed on a surface that is horizontal when the model is in normal level
flight attitude. The long axis of the unit must be aligned with direction of flight and the servo connectors should be to
the rear of the aircraft. NOTE: It must be installed in an upright facing position. See “pre-flight testing” below and
watch the following video: https://youtu.be/a6ZaxkxoGUg
BINDING
MIke\"When Inverted Down Is Up And Up Is Expensive\"
Originally posted by steveh80128@aol.com View PostAny help is greatly appreciated Does motion rc even have a customer service number to ask questions about the products that there customers purchase
