Programming the 3 Pos Flap switch on DXe
  • Programming the 3 Pos Flap switch on DXe
    I've been trying to use the iPhone app to get the 3 Pos Flap switch to actually be all three positions. I was finally get to to at least function as a two Pos (N-1). It's functional as a full throw from the N to 1 position, when moving into the 2 position, nothing. This thing has horrible documention, and little in the way of Google and YouTube info.
    My call to HH support actually gave me wrong information. He stated the the firmware must be updated and installed using the PC (USB) cable to reassigned the channels. I actually worked with the smart phone app until I figured out that it can be done.
    The pull down menus refer to Aux, then Aux 1-4, however the actual manual for the reading don't refer to any of the toggles the same way so it's been kind of trial and error at this point. It just seems like a basic 3 Pos flap shouldn't be this difficult!
    My first post BTW! This is all new stuff for a Freewing A-10.
    Update. After a conversation with an incredibly rude and unprofessional tech support agent with HH, the three position flap switch on the DXe will never function as such, only a two position. Then we discovered none of the trim buttons worked, and needed to be sent in for warranty repair.
    As as it was only two days old, I went back to my LHS and exchanged it for a DX9 Black Edition (I know, night and day). Lesson learned, buy once cry once.
      Hi Setxwarrior. Welcome to the forum. :) sorry to hear of your troubles with the DXe and HH. I don't have that radio so couldn't offer any help. But, from what I've heard about the DX9 you'll be very happy with it. Also, you'll love the A-10. She's a sweet bird.
        Hey Thanks Prowler! I actually maidened the A-10 yesterday successfully! Twice. My second plane after I learned on the Apprentice, and was pretty nervous. Things happen much faster with the EDF, however smooth and successful landings (x2). 3 minutes goes by much faster when you're nervous!
          Congrats on the successful maiden! Yeah, three minutes goes by fast.
            I bought two DXe transmitters. One works fine and controls flaps and gear and other main channels on eFlite P51, however, the throttle control channel doesn't work on the other DXe. I just received a pc to DXe cable to update firmware on both of these and will then determine if the "bad" will one still not Control the throttle.
              Hi Guys
              Yea thats to bad to have a bad radio out of the box it can happen but never feels good. I know all to well about 1 person at HH that is very hard to deal with. I have reported him 2 times thus far. A little side note if you get a hold of this guy again you can ask to be transferred to another customer rep their. They are all not that bad actually just that one guy. That is why we strive so hard here to have the best customer service agents out on the market, and I feel we are doing this head on. I have never used the DXe radio but have heard of that very thing. That the flaps will not act as a 3 position for flaps and the app is not very good either. Again sorry to hear of the bad luck that you received hope all goes well and happy flying the DX9 is awesome!!!
                I too have had the same problem with the 3 postion switch for flaps, no good answers and must have talked to the same HH rep what a jerk Motion RC are the greatest to deal with PROS I also couldnt update firmware using the updater had to use the programmer that worked fine did get that tip from HH though got it from this forum . HH told me I had to send him proof of purches of the radio and a picture of radio dont know what that tells him.n Been a Futaba man for 20 years thought I would try spectrum so far between dealing with HH and the DXE I may switch back to Futaba
                  Bought a DXe transmitter with an e-flite timber 1.5 and after binding the flaps went to full flap positioning, discovered that if I push the bind/panic button the flaps will retract. What needs to be done to remedy this problem? Thanks, George
                    Hey George, give this a shot: https://www.flitetest.com/articles/how-to-setup-the-dxe
                    and welcome to the squawk!
                      Guys,
                      Im new to this site and using the Spektrum system. I have a DXE transmitter that does not have the flaps switch fitted as it was sold from a kit, anyway I have an AR620 receiver and it all works fine apart from the fact I want to program in flaps.
                      I should be able to use one of the other buttons for the flaps
                      I'm using 2 servos on the ailerons and have the laptop programming lead, Horizon Hobby were absolutely no use what so ever and just repeated everything I have done already even though I told them what I had tried in the initial email.
                      My 35mhz transmitter was a JR 2610 and I could program in flaps no problems
                      So my question is .............Can the flaps be programmed and how do I do it?
                      Thanks for your help and listening to my rant
                      Paul
                        I had the same issue but have a solution. I was able to get three-position flaps on the DXeA - the one without the flap or aux switches. The trick is to assign flaps (channel 6) to the FM switch. Note that FM Switch is different than assigning to flight mode,On my DXeA, I have SAFE assigned to the Rate switch and flaps to the FM switch, so i can control 5 channels plus SAFE - actually pretty decent setup - and I still have throttle cut switch.
                        • #13
                          Hi
                          Thanks for ur reply, I will give it a go and let you know my outcome.
                          paul
                          • #14
                            I have the same issue as George Herr . I watched the video and read that page, James I don't have the phone cable for my TX so i just ordered one. I'm able to fly the plane in SAFE mode even with the flaps fully deployed but its a pain. Hoping that I can figure out what needs to happen with those flaps. thanks for the help!
                            • #15
                              Welcome to hobbysqauwk mwiebe . I personally have never used this, just did some googling when this got posted to see if I could help. Seems like once you have that cable, then you will be able to get it all straight. Definitely report back with the outcome
                              • #16
                                Thanks James! I did buy the bluetooth connector and figured out the the AUX1 channel needed to be reversed for the flaps to sit in the right place. So thats good news.
                                Unfortunately I crashed the bird a few times and really did it some damage. The first crash I broke the prop adapter and cracked the fuselage and wing in a few places so I repaired them with tape. The tape didn't do it for the wing and I ended up splitting a bamboo chopstick and taping it onto the wing as a support. That made it as stiff as anything which I thought would be great.
                                On my first flight after those repairs I was testing out my bamboo by doing some backflips, it seemed to be working very well with no visible flex. I was flying a little too close to trees though and ended up crashing it nose-first into the ground, mangling the motor mount, and cracking the fuselage again. So I may be on the market for a new fuselage. Luckly I see they go for only $20, so I'll be getting one.
                                I think I might also invest in a better simulator before I go and do a lot of flying again. Any recommendations? I'm on a mac and I'm not really a gamer so I don't know how thats going to work. I'd consider getting a gaming system as well but I assume those are going to use the standard controller, not my actual controller. Anyway let me know! Thanks friends.
                                • #17
                                  guys, how can i assing the channels to my transmitter??
                                  i have the cable..how i change the switch lets say the rate swith to control flaps?
