I have struggled for years with finding the right iron which gives consistent results. I have tried many from HD to Amazon, but the one I have had the best luck with is the Hobbico 60w iron. But even with this one I do not have consistent joints, I make sure to clean the tip every use and also use flux regularly, but sometimes I cannot get the joint hot enough for a good flow, most of the time is great, and flows instantly. I use both the thick 1/8" as well as the thin electrical solder which does make a difference and helps. Just wondering what other irons are out there you have had good luck with.
Chris
Chris
