receiver glue?
  • receiver glue?
    What is the stuff horizon hobby uses to glue the receiver down? Seems like it's silicone, I have a AS3 to install. Just curious if just gluing it to the plane with CA would be ok or if I need something that would dampin vibration (gyro receiver)
    Or just using foam tac.
    Planes
    Horizon uses a white silicone caulk to glue some of their receivers and servos. I would not use CA to glue in a receiver, it's too brittle. I would recommend double sided foam tape (first choice) or hot glue (second choice and make sure to use low temp).
      Special electronics grade silicone "glue"
      Don't just grab any silicone.
        Thanks guys!
        My concern with double sided tape is it coming off during flight, normal receiver I wouldn’t care but since this has a gyro
        Planes
          Try: E6000 231020 Adhesive
          https://www.amazon.com/gp/product/B00JP3X9WE/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
            FOAM TAC ;)
              I have a lot of this, didn’t know long term effects, IE not suppose to use regular silicone on eletrontics. Don’t know the why, just know.
              Planes
                Originally posted by thisguy65 View Post
                I have a lot of this, didn’t know long term effects, IE not suppose to use regular silicone on electronics. Don’t know the why, just know.
                The gassing out (acidic effects) of regular silicone as it cures is the detrimental aspect to a non conformal coated circuit card.
                These Rx's are encased in a plastic housing so it is really not an issue to use silicone but..............use the Foam Tac. ;)
                In my early years in a DoD manufacturing facility working on computer systems like Wild Weasel, Space Shuttle, B1B, S3A, F15, etc, the use of Dow Corning 3140 RTV was the standard sealant/adhesive used by techs for fixing the adjustment screws on circuit card potentiometers. I still have a 6 pack box of 3oz tubes from 20+ years ago and it is still good to use.
                  Thanks guys!
                  The double sided sticky cushions as supplied with Lemon (and Admiral) RX's won't come off. It's made by 3M and very good adhesion to foam and plastic. However, there are times when I install on wood, so I put a little FoamTac on the sticky part that touches the wood for insurance.
                  When you have a gyro device, a solid mount is not desirable. A cushion like material is the best way to minimize the effects of vibrations.
                    It is a high temp rtv for electronics, Silicone Rubber White Glue Kafuter 704 that they use and you can get it off ebay and amazon.
                    AMA 424553
                    • #11
                      Guess for added insurance just add a little foam tac to both sides of tape? Call me paranoid
                      3M tape you get from Walmart?
                      Planes
                      • #12
                        Yes, Wal-mart, Home Depot, Office Max, etc.. It might be under the Scotch Brand (which is also 3M)
                        • #13
                          Well, I guess if you're that way, then sure. But be advised that the 3M tape when stuck onto a plastic surface like the bottom of a RX, is almost impossible to peal off when you want to. It has to be razored off if you want a clean start. That's how sticky the stuff is.
                          • #14
                            This?
                            https://www.lowes.com/pd/scotch-1-in...BoCHTEQAvD_BwE
                            Planes
                            • #15
                              Your link doesn't seem to work for me. It's this ................
                              https://www.lowes.com/pd/Scotch-1-in...d-Tape/3690666
                              You can also use double sided servo pads from HobbyKing. It's a bit thicker to offer more vibration damping and comes in big sheets that you cut to size.
                              • #16
                                +1 for E6000
                                • #17
                                  I've been using alot of velcro in my set ups. If you wanna change parts, just rip it off and use it in your other model. Or visa versa.
                                  • #18
                                    Originally posted by bob_stan View Post
                                    +1 for E6000
                                    I'm surprised no one mentioned shoe goo. car guys use that to reinforce the lexan bodies. it does a great job on foam and rubber etc. and the 3m gray tape to mount receivers, speed controls etc.
                                    • #19
                                      I found this stuff, https://deluxematerials.co.uk/products/fix-n-flex the local hobby shop had it. I cannot find foam tac anywhere. not one single hobby shop i've called or been to has ever heard of it and they all have tons of foam planes. I tried the CA foam safe glue by zap, it sucks. I've tried the bob smith industries foam cure, it come off plastic too easy to hold anything to the foam. zap goo melts foam. hot glue pops right off of plastics so it wont hold parts in the foam.
                                      I don't want to order stuff from china like the kafuter 704. says it will be delivered in 2 to 3 months. ridiculous.
                                      so far the fix-n-flex is working the best on test pieces. it's soft like the silicone eflite uses on my apprentice sts.
                                      • #20
                                        E-2000 also known as Goop, great stuff...stays a little flexible so it doesn't get brittle.
