Wiring.
  • Skyboom
    Foam flyer
    • Nov 2018
    • 344
    • Chilliwack, British Columbia, Canada
    Wiring.
    I wish they would only make one type of plug. This soldering sucks.
  • Skyboom
    Foam flyer
    • Nov 2018
    • 344
    Wish they would make all the plugs the same. My soldering sucks but works.
    • RRHandy
      Instructor Pilot
      • 895
      • Lilburn GA
      Send it all to me in Georgia and I will do it for you.. R.
      AMA 424553
      • Skyboom
        Foam flyer
        • Nov 2018
        • 344
        Thanks. I have a freewing Yak and HSD Viper next. Finally found a place to fly them. In Ferndale Washington.
          • 8822
          If you do soldering enough and watch YouTube videos on the subject, you’ll get real good at it. I don’t mind soldering now although I rarely have to anymore. I buy adapters for every possible combination of ESC to battery configurations now. From time to time, I’ll buy and ESC that doesn’t have a connector at all an on those, I’ll put an EC3 or EC5 on. Those are the easiest to deal with.
          • Skyboom
            Foam flyer
            • Nov 2018
            • 344
            Yes soldering bullet connectors to an esc is my worst nightmare. I've crimped connectors on them before . Even if I do get a soldering joint, I can never get the heat shrink over it. I have the third arm for difficult joints. I'll just have to keep practising at it.
            • RRHandy
              Instructor Pilot
              • 895
              • Lilburn GA
              The only problem with adapters is that you introduce more resistance.
              R.
              AMA 424553
                • 8822
                R.
                I'm sure it does but is it significant enough to worry about? Personally, I can't say I've noticed.
                It's like the old coffee commercials that used to say their coffee was 99% caffeine free. They didn't stop to tell people that non-decaff coffee was only 3% caffeine by content. "More" and "less" are relative terms.
                • Skyboom
                  Foam flyer
                  • Nov 2018
                  • 344
                  I concur with xviper. I consider bullet connectors to be adaptors. It's where you have too many amps being drawn through a small connector where the problems arise. Rule of thumb "use right connector for right wire". You can run lots of stuff from one wire.
