Foam Safe CA Viscosity
    • 8236
    Curious about how folks consider the viscosity perception of foam safe CA glue. For me, I consider anything with the "Thin" designation as the consistency of water. Easily drips. "Medium" has a more gel-substance to it. Not super thick but doesn't drip as easily. "Thick" is even heavier gel-like and hard to drip. Does this sound about right to your experience? Curious and thanks for any responses.
    You're pretty much spot on with the viscosity analogy from my experiences with many brands :ok_hand:
      • 8236
      Great, thanks for the response...Interested to hear if others feel the same...
        • 8822
        Same.
          Yep, spot on. As for uses, thin is for parts that fit tightly together with no gaps. Medium and thick take longer to set and can fill and flow if the are some small gaps in the parts fit.
            So Aros ………. got to ask what prompted the question. Is it because of the new BenchCraft Foam Safe CA's ?
            If so, I have some customer input on it for some I recently purchased and just 5 minutes ago used it for the first time on a scratch build foam project.
            I ordered the Medium which has the consistency of what would be a thin CA as confirmed by myself and XV and TJ of your viscosity analogy in first post
            NOT impressed if this is the standard or maybe it is a bad batch. :unamused:
            Some one needs to look into this. :pop
              The thin is VERY thin as well. I've found that if you use the thin or med on a non-porous material, you pretty much have to use a kicker. You also use less that what you are used to. On wood, it penetrates and cures well.
