Pilot Painting Service
  • AkumaZeto
    Achtung Stormtrooper
    • 907
    Was suggested I start cranking some of these out for people. I will say the softer the sculpt the less detail it will have. With that in mind pick your busts or figures accordingly. FMS stock pilot cant look much better without sculpt work. But the Ices of Iron are a good choice.
    100 for 1/3rd 1/4 1/5 busts you supply bust
    50 for 1/6 1/7 1/8 you supply bust
    Turn around time right now as I have zero to do is about 1.5 weeks. Mostly drying time as I use oils and acrylics and even lacquer.
    All models painted with high quality Tamiya Vallejo Or Mig Abteliung 502 paints.
    Resin pieces are washed and then primed with Badgers Stylenrez one shot self leveling primer.
    Here is a example of my recent 1/6 Dystopic build. Keep in mind the level of detail on this models sculpt with a basic PNP pilot in your stock plane.
    Also included here is some 28mm figure painting to show the level of detail achieved in this small range. Again its all about the sculpt.
    Click image for larger version  Name:	IMG_20171110_215105346_HDR.jpg Views:	2 Size:	59.1 KB ID:	105273Click image for larger version  Name:	IMG_20171112_211017885_HDR.jpg Views:	2 Size:	74.9 KB ID:	105274Click image for larger version  Name:	IMG_20171112_211036309.jpg Views:	2 Size:	55.2 KB ID:	105275Click image for larger version  Name:	IMG_20171112_211111180_HDR.jpg Views:	2 Size:	69.5 KB ID:	105276Click image for larger version  Name:	IMG_20171106_125817337_HDR.jpg Views:	1 Size:	169.6 KB ID:	105277Click image for larger version  Name:	IMG_20171106_211432547_HDR.jpg Views:	2 Size:	173.2 KB ID:	105278Click image for larger version  Name:	IMG_20171111_182202630_HDR.jpg Views:	3 Size:	75.8 KB ID:	105279Click image for larger version  Name:	IMG_20171111_182202630_HDR.jpg Views:	3 Size:	75.8 KB ID:	105291Click image for larger version  Name:	IMG_20171109_163627325_HDR.jpg Views:	2 Size:	75.2 KB ID:	105280Click image for larger version  Name:	IMG_20171113_184315298_HDR.jpg Views:	2 Size:	72.3 KB ID:	105281Click image for larger version  Name:	IMG_20171111_182254822.jpg Views:	2 Size:	64.7 KB ID:	105282Click image for larger version  Name:	IMG_20171109_154456162.jpg Views:	2 Size:	68.0 KB ID:	105283Click image for larger version  Name:	IMG_20171114_140134624_HDR.jpg Views:	2 Size:	84.0 KB ID:	105284Click image for larger version  Name:	IMG_20171114_135442097.jpg Views:	2 Size:	53.4 KB ID:	105290
    AMA 1102566
  • AkumaZeto
    • 907
    Click image for larger version  Name:	IMG_20170324_222029882.jpg Views:	1 Size:	166.0 KB ID:	105294Click image for larger version  Name:	IMG_20170324_221345923.jpg Views:	1 Size:	56.8 KB ID:	105295Click image for larger version  Name:	IMG_20170325_190304600.jpg Views:	1 Size:	53.0 KB ID:	105296Click image for larger version  Name:	IMG_20171022_192252594[1].jpg Views:	1 Size:	165.9 KB ID:	105298Click image for larger version  Name:	IMG_20171009_212606921[1].jpg Views:	1 Size:	84.8 KB ID:	105299Click image for larger version  Name:	IMG_20171102_094454800[1].jpg Views:	1 Size:	162.1 KB ID:	105300
    AMA 1102566
    • AkumaZeto
      • 907
      AMA 1102566
        Really top notch work, AkumaZeto. Best of luck to you!
          • 8205
          Holy cow, I know who I am going to come to when it's time to order my 1/5 scale Pappy Boyington for my ESM Corsair! Amazing work! What would be the cost for the 1/5 Pappy?
          • AkumaZeto
            • 907
            Click image for larger version  Name:	6a00e553cb00e488340147e27cd585970b-800wi.jpg Views:	2 Size:	103.7 KB ID:	105479
            Thought he came painted? Would be 100-110 though
            AMA 1102566
              • 8205
              No he comes unpainted. You can go through a service they offer to have it painted for $165 so it's a no-brainer! I will message you when I am ready to purchase. I will just ship it directly to you.
              • AkumaZeto
                • 907
                Click image for larger version  Name:	IMG_20171202_153959595_HDR[1].jpg Views:	1 Size:	145.3 KB ID:	106765
                AMA 1102566
                • AkumaZeto
                  • 907
                  AMA 1102566
                  • Westsider
                    Fly more, work less.
                    • Nov 2015
                    • 333
                    • NorCal
                    Mad skills man, mad skills! Truly amazing.
                    • seaviper
                      ATC retired
                      • Aug 2016
                      • 1092
                      • Philadelphia Mississippi
                      I have one of those pilots that needs painting. And I am NOT looking forward to it.
                      • AkumaZeto
                        • 907
                        Thanks fellas. I could use all the work I can get this time of year. Here is the completed pair. Anytime there are hoses I paint them but leave them off. Customer needs a small dab of CA to affix once situated in the cockpit. I dont recommend cutting or attaching anything until its in its final resting spot. I cant give any kind of recommendation either on how to affix these guys. Never done it myself so cant speak to that.
                        AMA 1102566
                        • AkumaZeto
                          • 907
                          AMA 1102566
                          • RRHandy
                            Instructor Pilot
                            • 892
                            • Lilburn GA
                            What a difference in four hours, Very nice.
                            AMA 424553
                            • RRHandy
                              Instructor Pilot
                              • 892
                              • Lilburn GA
                              Even nicer.
                              AMA 424553
                              • AkumaZeto
                                • 907
                                These pilots are out the door and done already. Received Friday and finished them over the weekend. Thanks Scott!
                                AMA 1102566
                                • EA-6B Geek
                                  EW Misfit
                                  • 485
                                  • South Central Ohio
                                  These came out fantastic! Thanks AZ! I still can't believe how quickly you got these done and back to me.
                                  • Prowler901
                                    • 940
                                    • Gunnison, CO
                                    AZ, you are quite the artist! Amazing work on all of this. :Cool:
                                      • 8205
                                      He received my 1:5 Pappy today...I can't wait to see his stellar work on mine!
                                      • AkumaZeto
                                        • 907
                                        Primer and base coat down. Click image for larger version
ID:	108329Click image for larger version
                                        AMA 1102566
