I have been out of the hobby for 12 years . I would like to get back in to it .I would like to know if anybody could recommend a good transmitter that is easy to program. Thanks
Transmitter help
Hi Gun Dawg 34, welcome to Hobby Squawk!
What radio did you fly in 2005?
There are several key radio brands out there now. Some brands like Spectrum have multiple radios at different price points so you can choose your point of entry, like, 5 channel, 6 channel, 8 channel, 9 channel, 18 channel, and Spektrum radios are also compatible with Horizon's wide array of BNF planes. Some brands like FrSky have fewer radios, but higher overall channel counts, like 16 and 32, with creature comforts including color screens and built in RSSI telemetry (signal strength). Futaba, with whom you're probably familiar, is still around with dependable systems. Airtronics, though, and a couple other brands have either stopped or slowed their new product pipeline. Brands like Detrum offer low cost without high end options, if you're less interested in features and most interested in low price and support from Motion RC. Brands like Jeti and Mikado offer great radios at the higher end, but you have to ask yourself what radio your local club flies... with any modern computer radio system, it would be an advantage if you had a radio that your buddies also had. It makes learning the radio that much easier, plus you can buddy box with them. Conversely, if you're the only guy with that special radio.. you're on your own.
Altogether, the radio transmitter is the most essential tool in your RC kit. I'd recommend researching, comparing, and ultimately investing in a future-proof radio system that you can grow with, since you're starting from scratch in what is basically 2018. Take it from the guy who has flown over 20 different radios from at least 11 different brands... you don't want to relearn multiple menu programming pathways unnecessarily.
In terms of difficulty, learning curve corresponds to feature set. Basic radios will be easier. As far as which brand is easier, it depends on what your reference point is. People who start with Spektrum swear it's easier than FrSky. People who start with FrSky swear it's easier than Spektrum. The same could be said about the other radio brands out there. My point is, don't let any brand's perceived complexity dissuade you. Decide on a feature set and a price ceiling, then get to comparing!
My current daily drivers are an FrSky X10 (16 channels), a Spektrum DX9 (9 channels), and a Futaba 10J (10 channels).
Learn from our mistakes, err, my mistakes. Out of the hobby 30+ years, have an ancient futaba fps-4 channel and expert 7 channel. Started seeing these magnificent scale electric warbirds and jets offered by Motion, watched all the videos with pilot Ryan and captain Mike (as always) and was totally drawn in! Anyway, DO NOT make the mistake of buying the Tactic 6 channel, because the next plane you’ll want to buy is the Horizon Opterra, and that requires a Spectrum radio, and don’t get the Spectrum DX6, because two months later you’ll wish you’d got the 8 or 9 channel. Don’t do that. That’d be stupid. :Angry:
I think the point above (don't go tactic 4 ch and don't go 6 ch) was to get 8 or 9 channels (or more) from the start so yo don't have to keep buying radios to get the number of channels you want/need for future aircraft.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
G'day Gun Dawg,
I can totally recommend the Futaba 8J as that is my daily drive but if I had of waited six more weeks, the 10J would have been on the market and this is what I would have purchased.
Relatively light, a good feel in the hands and very easy to program. And the 10J has telemetry as well.
I have not had any problems with my 8J at all.
Regards and respect
Daryl
I do recommend Spectrum and an 8-9 channel radio. Futaba back in the day was number one radio overall. But with them making a dictionary to go threw put them in the back burners. Spectrum has hundreds of threads and youtube vids on just about anything. If you like e-flite planes they are all spectrum radios only. So add that to your thoughts as well.
G'day GD,
One thing I should add to the conversation.
If you are going to join a club (recommended) or are in a club, have a look along the flight line and chose a transmitter that is popular among those who you will be rubbing shoulders with.
Reason, they can help you if you if you find yourself in need of assistance with the transmitter.
Stay away from being the only kid on the block with a fancy do da, rip torn transmitter that no ones knows about because if you do not know, we do not know either.
You might look impressive with the multi featured, thousand switch transmitter in your hands but it comes to nought if you can not fly because no one on the field knows anything your transmitter to help you.
Futaba have greatly simplified their transmitters of late as they were trying to out tech others with all the whiz bangery and complex looking programming frightening people with over complicated programming steps.
Regards and respect
Daryl
13.5 hr is low for a transmitter to just up and die.
They should work for thousands of hours.
There is one Futaba F8UAP still in occasional use in our club. It was made in 1990 and had seen 2 to 6 hours of use per week from then until 2008. 3000 hours of operation would be a conservative estimate.
Normal use, the gimbals or switches should be the first things to fail.
I'd estimate over 2000 hours of use on my first DX-18 before its roller switch failed. (I installed a $15 upgrade roller and it works again) I replaced the battery simply because it was more than 5 years old and I just don't trust LiPos that old.
DX-8 should operate over 6 hours per charge with the original battery. (much more with the optional LiPo battery)
I've never looked for a total operation timer on the Spektrum (or any other) computer radio. Possibly your time exceeded its display limit.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Could have I guess. I'm pretty sure I used it alot more. And in some instances put close to 5-6 hours on it in a single day when I had an opportunity for it. When I was in the army soon as final formation was over for the day I jumped in the car straight to the field and flew constant til the sun set almost every day. So I know that timer is off now that I think on it.
I flew Futaba exclusively for 20 years. I took some time off from flying RC to play with full scale airplanes. When I decided to come back to models, things had changed considerably. I purchased a Spektrum DX6 and it worked fine and was easy to program. Like the others here have said, my next models wanted more channels so I went with the DX18G2. It has worked flawlessly and I have been very satisfied with how to program it. There is a lot of help online and at the field for the Spektrum radios.Originally posted by Gun Dawg 34 View PostI have been out of the hobby for 12 years . I would like to get back in to it .I would like to know if anybody could recommend a good transmitter that is easy to program. Thanks
Yep that is where I’m at now got the DX6e. Great entry level radio. But now I am wishing I had got the DX9 because the P-47 I want from Horizon Hobby needs at least 7 channels & when I told my mate that I had brought the DX6e he said it won’t be long before you wish you had more channels. DOH I hate it when he is right.Originally posted by Boots Whirlygig View PostLearn from our mistakes, err, my mistakes. Out of the hobby 30+ years, have an ancient futaba fps-4 channel and expert 7 channel. Started seeing these magnificent scale electric warbirds and jets offered by Motion, watched all the videos with pilot Ryan and captain Mike (as always) and was totally drawn in! Anyway, DO NOT make the mistake of buying the Tactic 6 channel, because the next plane you’ll want to buy is the Horizon Opterra, and that requires a Spectrum radio, and don’t get the Spectrum DX6, because two months later you’ll wish you’d got the 8 or 9 channel. Don’t do that. That’d be stupid. :Angry:
I hear you, I have a DX 6e that sits on the bench as well. As soon as you go for flaps and retracts, you've just bottomed out. Three position switches are nice as well, I broke down and admitted my mistake and got a DX8 1st Gen which I've used for going on three years now (WOW!) and still going strong.
f I had to replace her, I'd probably go something with 10 channels, even though I might not use them all, I've been picking up 10 channel Lemon receivers and a great price so, if I ever want to add on the radio is capable.
Grossman56Team Gross!
I ran out of channels on a X9303 2.4 ghz... and said F it and got the DX-18.
NOW run THAT out of channels!
Yep, I can. :eyeswide
Nothing that NEEDS 18 so far, but 8 flap servos can make a dent in your channel count. (flap system to get scale movement on 107 inch Me-262)FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
