Would anyone be interested in an aircraft Building Service ?
  • Calvarycustoms
    • Dec 2017
    • 9
    It looks like I will be out of action for the foreseeable future due to knee surgery, so I have figure I will offer my building skills as something to occupy my time while I recover.
    I have been building R/C Aircraft for over 30 years. I have built everything from gliders to trainers to warbirds, pattern planes, ARF’s, ARC’s, heli’s, scratch built and short kits. Most builds can be done in 1-2 weeks (yes I am a work-aholic). I can also install radio gear and engines, covering, airbrush and do custom graphics also. Builds can be done any completion level you would like, ARC, ARF, or RTF.
    If you are to busy to build that kit that's in the rafters, or don’t think you have the skill to build that plane you have been wanting, shoot me a message and let me know how I can help. If you have any questions, please let me know
    I will take projects on a first come first served basis. Depending on how many projects I have lined up will determine how long it will take to complete your plane. I will let you know how many are ahead of you and what the approximate completion date should be.
    ARF’s…………………………......$ 1.50 per Inch.
    Gliders……………………....……$ 2.00 per Inch.
    Trainers…………………...……..$ 2.50 per Inch.
    3D/Pattern Aircraft…….……$ 3.00 per Inch.
    Bi-Planes……………..……..……$ 3.50 per Inch
    War birds……………….….….…$ 4.00 per Inch.
    Giant Scale Kits………..…….$ 4.50 per Inch.
    I may also consider doing some trading
    Other Services Available;
    Engine Installation:……………Starting at $10
    Radio Installation:…………….Starting at $15
    Covering……………………...…..Starting at $75 (plus material)
    Custom Graphics: ……………Ask for a quote
    Airbrushing:………………..……Ask for a quote
    Terms and Conditions;
    -All prices are per inch of aircraft wingspan.
    -50% of total due at time of order, balance due upon completion.
    - Pictures of the build process will be available at any time and will be emailed upon request.
    - Glue and epoxy will be provided. Any other parts or equipment to be used will be provided by the aircraft owner. Such as control horns, push rods, wheels, wood, fuel tank, fuel line, nylon bolts, screws, covering, engine, mounts, radio equipment, retracts, ect… These items can be purchased and sent to me. If it is easier, the cost of these items can be added to the 50% deposit and I can order them.
    -Return shipping will be the responsibility of the aircraft owner.
  • R wood
    • Dec 2017
    Where are you located?
    • Calvarycustoms
      • Dec 2017
      • 9
      I'm in Lansing Michigan, but I can ship just about anywhere
