Mixing aileron and elevator.
  • JAG
    • 10
    JAG Hi Guys.....just wondering how to mix aileron and elevator on new Crusader? I am using a DX7 for radio. Want to get the controls to work properly. Thanks
  • ryramZ
    Pilot Ryan
    • Dec 2012
    • 814
    Aircraft type must be set for elevon.
    • fhhuber
      • Aug 2015
      • 1476
      Yes, pick ailerons or elevator as the primary, then mix the other surfaces. (assumes 4 servo setup)
      Note: when using elevon mix, if the closest you can get to correct control movement is correct aileron and reversed elevator, then swap which servo is in which channel. It will instantly be correct.
