Hey all, thanks for taking the time to look at this post. Flying my FMS Yak I’m running into a recurring issue.
Aircraft: Stock FMS Yak-130
Battery: Floureon 6s 45c 3300mah
Receiver: Admiral RX10000
Radio: Spektrum DX8E
On my second flight I was turning in on final and my motor cut out. In my flight video you can hear it just cut out completely but flight control surfaces remained operational and I was able to glide it in. Unfortunately it went into a backstop with very minimal damage and I was able to get it back together with. Foam tac, boiling water and a new nose cone. As soon as i got to it I did a function check and motor spooled up and flight surfaces worked again.
i threw in a capacitor on an empty channel in the receiver thinking that it was a brown out issue. And a week later (today) I took her out for another go. The first two flights were uneventful and great. The third flight on the same circumstance, turning on my final I applied flaps and the motor cut out again with the same operational flight surfaces. I didn’t have enough altitude to recover and lost orientation behind the surrounding fence but I did the best I could to level out and down she sailed into the canyon below. Fortunately for me, she flew into a tree a good 5 feet from a trail. I was able to find it by moving my control surfaces and revving the engine. Damage was minimal with slightly dinged nose cone and leading wing edges taking a brunt of the impact.
it doesn’t seem like I’m having a brown out. Could the system be overloading causing the motor to cut out but still leave me the flight control surfaces as a “fail safe.”
I thought id consult with the more knowledgeable pilots on here since I’m left scratching my head. Thanks for your time.
