Best Foam airplane from Freewing AT-6
  • JAG
    • 10
    After building 16 foam airplanes from fighters to bombers, I have determined that the Freewing AT-6 is by far the Best model I have every built. The instructions were very well laid out, not like the one's from almost every other model. The model is strong well built and so simple to assemble my five year old grandson could put it together in about an hour, it took me all of thirty minutes. I'm somewhat of a slowpoke because I have to have everything just right. I gave this plane a full five rating because it deserves it. Strong, well built, The detail is off the chain, and so easy to put together with mostly screws, very little glue. Freewing did all the building and fine tuning for you all that's left is the major components, wing to fuselage, tail feathers to the fuselage, test the gear and you are done. WOW, you can tell I'm very excited about this model AT-6 from Freewing and MRC. Thanks to everyone involved...What a Christmas!!!
    • 7371
    RE: Best Foam airplane from Freewing AT-6
    Sounds awesome, don't forget to post pics in the Hangar!!
