ESC problem f7f
  • MichaelJ
    • 78
    ESC problem f7f
    I somehow set the brake on one of my escs when trying to calibrate it seams the f7r and the b24 are different any help?
    theres an esc manual for the plane on this page.
      • 8753
      First, the Tigercat is a 2 engine plane and the Liberator is a 4 engine plane, but the principles behind their ESCs are the same. You must have attempted to calibrate in a way that the engines initialized at different times or you waited too long on the one that you set the brake on. Isolate the one that you set the brake on (ie, disconnect the other one) and use the manual instructions to turn the brake off.
