Retract ???
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Retract ???
    I have a pair of Eflite retracts in my Corsair and love them but they are not smooth . They seem to what I call jerk a little bit opening and closing . I have cleaned and even used some White Lithium grease on them but no change . Anyone know a solution ???
    Bryan
    But Crashing is Landing
  • Woodcock
    Old Returning Pilot
    • Apr 2018
    • 830
    • SoCal
    Bryan
    I can concur, mine are a little, say, grindy. But they always go up and down. Love that they're all metal.
    Woody
      I would think it would be due to the rotation pin design. As its rotating, they could be very slightly binding, but not enough to completely stop operating.
        • 8754
        Precisely! The Corsair retracts have always been a bit "fussy". That rotation pin has to "catch" that sort of edge plate in order to do the rotation. On my 1700mm FMS Corsair, that little plate can snap off if the gear is subject to a harsh hit on the ground. I had to build new plates and position them just so or the pin won't catch it right. This is what causes the herky-jerky motion when the retract goes through its cycle. If it gets "hung up" or stuck, this will also snap the little plate or damage the retract itself. Observe the action of the pin and plate to see exactly how it works and then figure out a way to modify it to make it work best.
        • Woodcock
          Old Returning Pilot
          • Apr 2018
          • 830
          • SoCal
          Bryan
          Good idea, check to see if the rotating pin is catching on the mounting screw on the same side as the pin. Mine actually did this, and I had to get a new flush mounting screw just for that side.
          Woody
