Any recommendations for EDF brands other than Freewing?
  • chipset35
    • Aug 2018
    • 129
    Would love to buy an E-Flite EDF but do not see any I would like to purchase yet.
    Been researching FMS and Dynam, but it seems like the quality varies per model.
    I like Freewing's large selection, but their foam is too brittle IMHO after owning one.
    I am currently considering the Dynam A-10 and ME-262, the FMS A-10, and the FMS F-18 Super Hornet.
    Freewing isn't the problem, I've been following your post and it sounds like maybe you're not ready for an EDF...what planes did you fly before getting the F-86?
    • chipset35
      • Aug 2018
      • 129
      E-Flite F4ZF Wildcat and P-47D Razorback 1.2. (flys perfectly every time regardless of having AS3X or not).
      Not gonna rehash everything I already mentioned in the other post, but one point of clarification, my F-86 is the 64mm version, not the larger version.
        I have one of those and it flies great if you launch it straight out and not up. Also make sure you calibrate the ESC so you have the full throttle range.
          George, did you glue your fan in place?
            No, but when we face plant these things that little lip or glue just won't hold them in.
            • hotrod23t
              jim jets
              • Nov 2017
              • 312
              • EUSTIS FL.
              I had one of these small edf planes from fw and if you don't get the set up right you WILL CRASH get a rebel great first jet
              • hotrod23t
                jim jets
                • Nov 2017
                • 312
                • EUSTIS FL.
                In my opinion anything other than a freewing is a step down in quality with a few exceptions
                • Evoman
                  • 567
                  If your still new to EDF's you should really be looking at airplanes with flight characteristics that are easy to handle. Just like new RC pilots should start of in a trainer such as a Cessna so does the same concept apply to moving up to EDF's.
                  These are the top rated EDFs for newbies:
                  1. FW Hawk T1 70mm
                  2. FW Yak-130 70mm
                  3 FW F-86 Saber 80mm
                  Even though these are not my top favorites I recognize they will better prepare me to move up to EDF with less of a chance of crashing.
                  Even in the Arm Forces you have to work your way up in different trainers before you can fly a top tier fighter.
                  Click image for larger version  Name:	Training Pipline.jpg Views:	1 Size:	48.9 KB ID:	147129
                    • 8795
                    "After owning one"? That's not sufficient to make a wholesale blanket statement about the model line.
                    Dynam A-10 .............. underpowered. If you fly off grass, you'll likely not get off the ground and/or crash trying. Poor choice as many have discovered, myself included.
                    Dynam ME-262 ,,,,,,,,, 4 cell power, may also be a bit anemic.
                    FMS A-10 ........... are you consistently greasing your landings? The gear on this one will likely snap out of the mounts if you have a rough landing (witnessed this first hand myself).
                    FMS F-18 ........... This is a fast jet. If you believe you can handle it, get it. It's a good quality, good flying model. Landing can be a bit fast even with full flaps. (Seen it myself.)
                    • fhhuber
                      • Aug 2015
                      • 1476
                      Dynam Me262... 110 mph straight from the box, set up exactly by the instructions. Handles reasonably smooth grass fine. Gathers up sand burrs like crazy though. doesn't take much foam cutting to fit in 4S 5000 mah and it likes the extra capacity.
                      After adjusting CG and the horizontal stab incidence (see my review on MotionRC website), it can do an outside loop, but when adjusted for this, you must use care not to do 3/4 loop on takeoff, since low airspeed and high power will overcome full down elevator.
                      Stall recovery due to holding a steep climb too long is hit the rudder to point the nose down, before it flips onto its back. (similar to the 3/4 loop on takeoff, low airspeed and high power = don't do it.
                      Does not like tight turns because of loss of airspeed.
                      Very smooth flying model once trimmed out properly. The "bad habits" the model has are similar to "bad habits" of the full scale. (I did talk with the pilot of one of the full scale reproductions. MUST watch for excess power for the airspeed. The low slung engines push the nose up.)
                      Yes, the Dynam A-10 has issues. they can be solved. Not a good first EDF model but it can be made to fly reasonably well.
                      • McLogo
                        • Aug 2018
                        • 36
                        • Switzerland
                        Originally posted by Evoman
                        If your still new to EDF's you should really be looking at airplanes with flight characteristics that easy to handle. Just like new RC pilots should start of in a trainer such as a Cessna so does the same concept apply to moving up to EDF's.
                        1. FW Hawk T1 70mm
                        2. FW Yak-130 70mm
                        Can the FW Hawk T1 70mm or the FW Yak-130 70mm start easily on cut grass fields?
                        I'm not yet directly planning to buy a larger EDF jet yet... but maybe in a few month with more flying experience.
                          I fly my Hawk off of cut grass all the time. Gobbs of power!
                          • Quickstop
                            • 275
                            Seems to me like you have to do some (any?) research.
                              • 8795
                              Can't speak for the Hawk, but I fly the Yak 130 off grass even before it's cut. It's got plenty of power but you might want to install the optional trailing link mains. I belly land mine.
                                I have both the f18 and A10 from fms. Heres video of both on my very rough grass fields all stock.
                                  And the A10. Only thing I did add was a BEC. Just do not trust the internal ones in the stock escs. However the f18 is totally stock running off just the stock esc internal bec.
                                  • AZFlyer
                                    EDF and Scale Warbird Pilot
                                    • 194
                                    • Arizona
                                    The 70mm Hawk will do grass. The wheels are small, but the plane is so light, that it won't be a problem. You'll love that plane. It's my favorite.
                                    • McLogo
                                      • Aug 2018
                                      • 36
                                      • Switzerland
                                      Thanks a lot for the answers!
                                      • chipset35
                                        • Aug 2018
                                        • 129
                                        1. FW Hawk T1 70mm
                                        2. FW Yak-130 70mm
                                        Thanks Evoman!
