Aug 1st, 2018, 07:01 AM
Here are some photos to get some ideas on my landing on the grass problem . the front gear bends and is coming off I must replace it . ,I had Luckily found this rock hobby F16 same design only the front gear wire is spring loaded , do you this this would help. any suggestions for a good fix for it other than this is I get the spring loaded gear in the photo
