Best way to attach receivers in Elo planes
  • Ump50099
    • Aug 2017
    • 4
    tried double sided tabs not sticking any help would be appreciated thanks ment to say epo foam
    • 8756
    Smear a layer of FoamTac on each side of the double sided sticky things (they're best if they are the thicker cushioned ones, especially if you're using stabilized Rx's).
    • boomer108
      Chief Boom
      • Apr 2014
      • 867
      • Chicago IL.
      I use the heavy duty outdoor Scotch double sided tape. Never had a problem yet. It's a red protective film on it.
        Ive been happy with the gorilla double sided heavy duty. Works really well in receiver and vtx installation
        • davecee
          • 179
          • Nashville, NC
          I put a thin layer of any type of compatible glue on the foam (or whatever) surface. Let it cure. Your good quality, thick, double sided mounting tape will then stick very well to that surface. Sticking well to the receiver itself should not be a problem
          • davecee
            • 179
            • Nashville, NC
            That is my favorite.
            • Ump50099
              • Aug 2017
              • 4
              Thanks appreciate the help
