E-flite Pulse 15e Basic with AS3X® 1400mm (55") Wingspan - BNF
  • E-flite Pulse 15e Basic with AS3X® 1400mm (55") Wingspan - BNF
    Can't wait until this plane comes out. I will be ordering one. Sure glad it is foam in case I do have a mishap.
    As I progress with the Artizan this should be the next step up in my pursuit to fly sport planes.
    My YouTube Channel
    RE: E-flite Pulse 15e Basic with AS3X® 1400mm (55") Wingspan - BNF
    Greetings,
    I concur....
    This one looks like it should be a blast!!!!
    Of course, it won't be a blast in the air very long, on a 3-cell.
    I definitely like the scheme and that its 1400mm.
    Clear Skies,
    Bill L.
    in OKla.
      I am definitely interested in this plane as well. Why do you think flight times will be limited on a 3 cell though? I looked at the specifications, and it uses a 2500-4000mAH battery, which should easily allow flights of 5-7 minutes with the larger battery size. That is about all I ever get on most of my foamies.
      Either way, I am anxious to see the flight videos from Motion once they get them in!
        Any longer than 6 or 7 minutes just increases my chances of crashing. :-)
        My YouTube Channel
          Greetings Guys,
          Sorry for any confusion.
          I'm sure using 3-cell batteries in the upper mAh/C range will surely provide elongated flight times.
          What I was eluding to was, in my mind, the pulse is not meant to be flown around at 1/2 to 3/4 throttle (although it most certainly could be) as it is a more dynamic full tilt boogie design. Any plane flown at full throttle the majority of the time won't typically get great flight times on a 3-cell, that's all I meant.
          I can't wait to pick up one of these my self to find out.
          Clear Skies
          Bill L.
          in OKla.
            Like to see this in a P'n'P. Don't need AS3X, don't want Spektrum TX.
            TP
            AMA 59376
              Greetings,
              I agree, don't need it in anything but a PNP.
              According to MRC's site it will be available in PNP for $209.00
              Clear Skies,
              Bill L.
              in Okla.
                Can't wait to try this out. Did you see where it can be trike or tail dragger?
                Should be interesting.
                  Also has optional floats. I may try those out this summer
                    Greetings Gang,
                    A had forgotten about the gear options, Sweet!!!
                    Any idea on ETA??
                    Clear Skies
                    Bill L.
                    in OKla.
                    • #11
                      Just pre ordered this plane. Pretty excited to get it!!!!
                      My YouTube Channel
                      • #12
                        Tom, I am having trouble with my e-flight p51.  There is very little servo movement when test surfaces. Is there some programming I need to do for the receiver?
                        • #13
                          Greetiings,
                          Nice job on the pre-order.
                          This plane should be a winner!!
                          Bill L.
                          In Okla.
                          • #14
                            Phoenix, If you have the BNF P-51D, you it is programmable but it should be programmed and ready to go out of the box. Make sure you have 100% movement on control surfaces programmed on the radio (sometimes we use a memory slot occupied by a prior plane and you get the old planes programming in your radio with a lower D/R setup). You may just need to clear the memory slot and start over with binding and setup. Also note, the AS3X does not kick in until you use some throttle. The movements from AS3X will be small but the amount of control surface movement from your radio should be normal. The directions state the amount of deflection for the rates according to how you want to set them up. If none of that works, go ahead and send an email to our support.
                            Back to the Pulse - Thanks for the business! It looks like the Pulse should arrive in about 1 more week (or so).
                            • #15
                              Greetings Tom,
                              One Week??
                              That's awesome!! Thanks for the update.
                              Seems to me I read somewhere that it might be offered in red.
                              Is that true or a possibility at all?
                              It's OK if they'll just come in blue.
                              Clear Skies
                              Bill L.
                              In Okla.
                              • #16
                                I can ask Horizon but their system shows blue only. They normally don't put products in their system until they are a couple months away and there is not any other color as of right now. I'd be pretty shocked if they made it in 2 colors.
                                • #17
                                  Greetings Tom,
                                  Indeed.
                                  I can't remember where I heard/saw/read about the other color but, I too would be surprised if they went beyond blue.
                                  That's OK, this is going to be an awesome plane in any color I believe.
                                  I can't wait to see Mike and Ryan put it through its paces!
                                  Thanks for your response.
                                  Clear Skies
                                  Bill L.
                                  In Okla.
                                  • #18
                                    I have a pulse 25 electric. Great flying plane.
                                    • #19
                                      Greetings Randol,
                                      I'm sure the 15e will fly great as well!!
                                      Clear skies
                                      Bill L.
                                      In Okla.
                                      • #20
                                        Yes, me too, I get mumbly fingers!  My old guy attention span kicks in!
                                        Just Kidding!  Hey this looks like a heck of a bird!!!!
