Advise on first edf jet.
    • 8835
    Did you replace the ESCs? The model has been notorious for them blowing an I lost two, one making quite a nice fire.
    No, both my Vampires kept the stock ESC and motor. Never had a problem with either power systems. I flew my first one at full speed into the ground. The manual for it indicated the wrong CG. It was later corrected in subsequent models. That incorrect CG, coupled with the plane's tendency to dive on sudden throttle application buried my first one. I later installed that system into a Flitetest Viggen and flew it for another 2 seasons. It never even hinted at any trouble. You must have just had a run of bad luck with yours.
    • Valkpilot
      • Oct 2017
      • 857
      Actually, I think it was the opposite, you got lucky, since the predominate comment in the Vampire's comments section talks about it.
