Counter rotating props Dynam P-61
  • Counter rotating props Dynam P-61
    Hey guys I have a Dynam p-61 that the engine would stutter, so I reset the speed control with the transmitter and now instead of rotating inward it counter to outside. Does it matter which way it counter rotates. And if yes how to I reset to go back to factory sets. Thanks in advance for any help.
    Easiest thing to do is just unplug two of the motor wires and swap them, doesn't mater what two you swap, it will get the motor turning correctly again. On a side note, I wasn't aware these escs had a programmable reverse option, thats good to know for future reference.
      Thanks rifleman_btx, I'll give that a try and let you know how it went.
        Sounds good, looking forward to hearing about the maiden as well :Cool:
