Alpha Jet
  • Crash man
    • Dec 2018
    • 9
    • Los Lunas NM
    Alpha Jet
    Can I use my receiver from mt Apprentice that has safe mode in my Alpha Jet Thanks
  • fhhuber
    • Aug 2015
    • 1476
    Yes and no...
    A couple of versions of the SAFE mode RX are out there. Easy to reprogram and essentially you can't program.
    Even with the ones you can't reprogram the issue is if the gyros operate the controls in the correct direction. You can get around that mechanically or by use of reverse servos. The mechanical reversing may or may not be easy.. That is based on access to the opposite end of the output arm on the servo.
    I'm no sure of the access in the Alpha jet.
    Then comes the issue of any mixing needed for the airplane.
    The Gyro system can be made to work The question is how hard you have to work to do it
    • Crash man
      • Dec 2018
      • 9
      • Los Lunas NM
      Thanks for the info I will just fly it with spectrum receiver
