Jp electromagnetic brakes
  • T-28 Trojan
    • Jan 2019
    • 5
    I just recently purchased my jp brakes they are the new version, so this unit dose not have the manual tention adjuster it has to be adjusted through the transmitter. I'm new to the hobby and I can't figure out how to work this thing with my spektrum dx8e. Can some of you guys guide me on how I can go about this?
  • wolpertinger
    Pilot ??
    • 313
    • Earth
    T-28,
    The brake force is adjusted by the travel settings of the channel you plug the brakes into. Look at page 29 of the DX8E user manual. Funtion list, servo setup then travel limits, scroll to axis and adjust. Remember to toggle the switch to adjust limits seperatly. Note that most people assign the rotary nob for braking as you can then control them better and not just off or on.. give it a try.
    Hope this helps.
    • Glos
      • Jan 2019
      • 4
      I have a 117 night hawk 70mm my front retract broke were the servo wire z bends into the retract arm .So I tried pulling it out to replace the retract but it was going to damage the foam .Since I glued it in with 5 min apoxy when building it so I’ve
      decided to pull out the half of the arm far enough to lock the retract in its down position and glued it with 5 min apoxy .Question now I can still still fly a good 5 min flight with all 3 retracts in down position..?
      • Glos
        • Jan 2019
        • 4
        Just add more elevator when flying you could get a good long sharp thin model knife to cut out your foam don’t worry you can use the
        White Foam Clay - Moldable Cosplay Foam Clay,Soft Squishy Molding,Perfect for Arts and Crafts Projects,Creative Art Supplies with Sculpting Tools
        This you can form to any shape and let dry then sand cut shape the way everything looked before this stuff is light as a feather.
          • 8795
          This you can form to any shape and let dry then sand cut shape the way everything looked before this stuff is light as a feather.​
          Please explain how these 2 posts (7 years apart), have anything to do with JP Brakes?​
          • Glos
            • Jan 2019
            • 4
            to access the servo arm. You have to cut out the foam and once you cut out the foam, you can access that area and repair it with the foam that you are about to purchase just roll a ball small little ball and push it in and it will automatically self form itself, and you just mold it with your finger exactly the way it looked before, and it will come out exactly the way it looked. You just have to remember the way it looked before so you could mold the foam exactly the way and it’s so easy trust me
              • 8795
              What the heck are you talking about???? What does this have to do with JP Brakes? These posts of yours do NOT belong here. Are you meaning to post in some other thread?
