As the outside temperature increases during the summer months, in many states it can get to be over 100 degrees. Give consideration to the radio and electronics in your model. Add the temperature of the day to the temperature of the ESC, battery, and motor and very soon things can start to fail because of an overheating problem.
Make sure you have a good through flow of cooling air, be sure you are using a battery with the right "C" rating for the model you are flying. Using a low "C" rated battery in a high performance model that requires power on demand will create additional heat that has to be dissipated somewhere. It's not just the Battery and ESC that can overheat, the Rx can get to the point where it stops working. If in any doubt check the safe operating temperature of the RX.
If you are using FPV equipment this can over heat and fail too.
Use the recommended equipment and don't be tempted to modify to increase the power and performance. If you are looking for high performance, invest in a high performance model and the equipment that goes with it. Increasing the power in an effort to increase the performance of the plane, can create an airframe failure due to over stressing with increased flight loads.
I am aware many of you will already know this, however the above can often be overlooked and keeping this in mind will save a model from a crash. If possible fly at a cooler time of the day.
Martin.
Martin.
