Motor/ ESC problem
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    Motor/ ESC problem
    Can anyone tell me why my new E-Flite 25 motor on a new Mantis 65A ESC will not start running until the throttle stick is about half way up? I'm using a 4 Ch. Spektrum rec. and a Dx6 trans. I've never had this problem. Thanks, Doc
    [hr]
    Never mind! I just fixed it. I turned on the trans, moved the throttle to full, plugged in the battery, let it beep, moved the stick down to off, let it beep, and walla! It works! Thanks, anyway. Doc
  • Pheonix
    • Aug 2013
    • 670
    RE: Motor/ ESC problem
    I was just about to answer. It was not armed correctly. Happy flying.
    • Rocketeer
      • Feb 2014
      • 1356
      Greetings Doc,
      No punn intended but, it looks like to cured it!! (ok, maybe a little punn)
      Glad you got it worked out.
      Bill L.
      In Okla.
