Need advice on aileron centering
  • Pilotguy
    • Mar 2015
    • 196
    • Las Vegas, NV
    The Hobby Lobby FJ-3 (F-86) is my first EDF and I’m not sure how to center the ailerons on the swept wing. Here’s 2 pics. My question is do I center the ailerons with the inner or outer part of the wing?
  • Rcjunkey
    Love that RC stuff since 1990
    • May 2018
    • 23
    Looks to Me that the photo on the right shows the aileron hinge is not centered, or aileron is warped
      • 8753
      When the wing or control surface is warped, you do the best you can. Have it test flown by someone who has some experience and then make adjustments as needed after that. Personally, if that were my plane, I’d line it up with the side nearest the fuselage as it’s got more material and is less likely to be warped. Then use the hot water trick and try to massage the rest of the wing straight (or control surface).
      A lesson to be learned - buy better known brands of products.
