Tip for wheels on gear
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    I was noticing that some of the wheels are mounted on threaded bolts used as the axels . I took a coffee stirrer from McDonalds or any where really and cut it the width of the wheel . I placed on the axel then slide the wheel over it ,took out any slop and prevents the threads from chewing into the wheels .
    Works for me just that I may throw it out there .
    Bryan
    But Crashing is Landing
  • WintrSol
    • Nov 2013
    • 499
    • Florissant, MO
    RE: Tip for wheels on gear
    Bryan
    I usually use a thin brass tube - it lasts longer.
    • Hippie 64
      • Feb 2014
      • 1049
      • Gaffney , S.C.
      I would like to use that , where do I find it ?
      Bryan
      • Rocketeer
        • Feb 2014
        • 1356
        Greetings,
        Agreed, the first thing I thought of was how long would the straw last?
        The brass tubing would do the trick.
        Good ideas guy's, thanks.
        Bill L.
        In Okla.
        • WintrSol
          • Nov 2013
          • 499
          • Florissant, MO
          Bryan
          My local Ace Hardware has thin tubing, both aluminum and brass, and also my local hobby shop. Looks like the same display, so they probably get them from the same source.
          • Hippie 64
            • Feb 2014
            • 1049
            • Gaffney , S.C.
            I found some at Tower , thanks .....
            Bryan
