I know this has probably been answered somewhere but I have a quick question. Regarding the hook-up of gyros and initialization. I have several planes that have the battery tray/receiver location on the underside of the planes. The gyros are also mounted underneath. My question is you read to quickly hook-up your battery and step away until the gyro initializes, then go and fiddle with the wires and putting the battery in it's final resting spot. If the plane is upside down while I'm hooking up my battery, then it is not in good position I would think for initialization. I mean the plane might be sitting at a weird angle in the back of my van when I change out the battery. You see pilot Mike hooking up a bunch of batteries of planes upright, sitting on the ground, removes his hands and lets the gyro beep, then puts on the canopy, etc. You can't do that when the plane is upside down.
Is this an issue....or it just doesn't matter as long as you have the gyro physically mounted correctly in the first place. P.S. I usually use the Eagle A3-L gyros.
