EDF jet
  • claytonias777@gmail.com
    • Jun 2019
    • 4
    EDF jet
    I have a 70 mm pediatric shot one of the blades are cracked I don't know how to get the spinner off it has no hole in it I don't want to damage the motor how do I do it
    • Jun 2019
    • 4
    Okay not pediatric I have a 70 mm EDF jet the spinner cap does not have a hole in it I do not know how to
    get it off without damaging the motor how do I do it
      Hi Claytonias777, please be more specific so we can help you directly. What EDF unit do you have? Do you have a photo of it? If there is no screw through the spinner cap, it's likely a press-fit cap. But to be sure, let us know exactly what you have. A picture would be the most helpful.
        • Jun 2019
        • 4
        I can't send you a picture right now but I do believe you are correct I think it is a press on snap-on cap I just don't know how hard they are to get off and how I would do it without damaging the shaft of the 2150 OutRunner motor
          • 8756
          If you tell us what kind of plane it is, you may not need to send a picture. Brand, name of plane might be all that’s needed.
